I would like to know if I can change the parameters of the kit MK111 to the followings:
(1) Pulse time adjustable : Between 1 minute to 30 minutes
(2) Pause time adjustable : Between 1 minute to 30 minutes
NORMALLY THE PARAMETER IS:
(1) Pulse time adjustable : Between 0.5s to 5s
(2) Pause time adjustable : Between 2.5s to 60s.
It appears that if I change C1, C3, R1, R2, RV1 and RV2 to a suitable value, I can obtain the above parameter.
I really need your valued advices and help to go forward with this modification. Please let me have the proper modification value of the components so that I can arrive to the above parameter.
Thanking you for your usual cooperation and coordination.
