I’m a totally new beginner to solder and to electronic kits.
I need some advice please for my first attempt.
My mk109 doesn’t behave correctly (but I guess I did something wrong !).
Actually the electronic dice never shows number 5, sometimes no led are on and number 4 leds are not correctly located (LD1, 2, 6 and 7). Numbers 1, 2, 3 and 6 are fine.
Please find below links to the pictures of the board (thanks for making allowances !).
Any advice is welcome, thank you.
Matthieu
Hi
The components look like they are correctly positioned.
Your solder work seems OK for your first time, I’ve seen worse
But it could use some little rework here and there, sometimes just heating the pad and solder again is sufficient.
Also, check if you didn’t cut the traces, check the continuity with a multimeter.
Best Regards
VEL337
Hi VEL337 (are you a humanoid or something with such a name
Thanks a lot for your feedback and for your kind words !
I’ll check these points and will let you know how it
Regards,
Matthieu
