MK108 Wateralarm
Could it be possible to pre-cut or perforate this PCB in the factory?
Currently it’s quite difficult to saw off the ‘sensor assembly’ with that little room to spare.
It’s also quite difficult to fit ‘normal’ (0.5mm2) wire in the drillholes, it would be nicer if the holes are a bit bigger and/or the pad is left blank for soldering the wire on the surface.
