MK107 Runing Light
You say that “Different LED running effects are selectable”. Can you say what effects?
reg
Leds run from one side to the other side.
Pattern depends on the # of times the program switch is pressed. Every time the switch is pressed, a led is added to the pattern.
Careful: this has to be done at eavery power-on, there is no pattern memory.
