Good afternoon… I’ve got two mk103 kits I’ve double checked everything and it seems ok from what I see. One unit doesn’t light at all and the other only lights as I first apply power by plugging in the battery.
Please let me know what I can check or troubleshoot.
Here’s the best I can do with the photo image as I don’t own a regular camera… I do see not perfect solder joints I did retouch up and still nothing. However I did meter out for continuity as well as voltage and continuity was OK, but I didn’t get voltage at some points including at the 4 LED’s. I’ve done three of these kits from Radio Shack and only one comes on only upon first powering up with battery. The other 2 are completely dead.
A couple of LEDs are mounted the wrong way round. Make sure flat side of led corresponds with flat side printed on PCB.
Soldering looks rather poor and might need rework.
If the problem persists, please contact our US support dept. at (817) 284 77 85
