Hi.
I have a MK188 that has been working fine for quite a while. Now it stopped working and lets all power through at all time; i.e. it is like I connected the batteries directly to the electric motor I have. The error arose as I connected and disconnected the power a couple of times and changed from a ~5 minute pause to a ~5 seconds pause. I don’t know if some component got burnt for some reason or what else it could be. The component VR1 gets suspiciously hot in a few seconds after connecting the power.
Any hints on how to solve this would be very welcome!
Thanks.
I’ve tried removing the IC. That lead to a total shutdown; no power came through (so no heat in VR1). Also checked T1 with a multimeter. No connection detected between the different ends, and connection to the card itself is good.
Check if you measure +5V between pin 1 and pin 14 of the IC.
If this is the case, then the power supply looks OK.
Most likely, the controller is defective.
Please check with your Velleman distributor for a spare controller or return it to:
If I got the right pins I measure 3.94 V.
I can see if I can get a new controller. I can’t find the papers right now, so I could use a reminder which one is the controller.
