MK 139 Proublems
I just put one together and it doesn’t work can I have a picture of the board my resistors covered up the numbers. I like to see the placement I am taking voltage reading and liking for bad joints,
Dink
Hope this helps.
E male me a good address, I like to send some voltage readings.
Any good place to check? I am using them for LED night lights.
There getting scarce to find.
Dink
It might be easier if you explain what is wrong with you unit also some clear pictures would help.
On the Microphone there is a tab on one side this is the ground for the mic.
Make sure it is soldered.
