Hello all,
I hope this is the right subject i post at.
I have some questions about the MK 126, car alarm simulator:
I want to know how much vdc the system outputs to the red led? I tried to messure but its a quick pulse so i cant see a value
I think that is the same LED in this link.
http://www.vellemanusa.com/products/view/?id=528113
So the LED needs 12 volts DC and flashes on it’s own.
Sry but your link doesnt work
Well the led in the set has a metall cover not plastic…
You say its flashing on its own so its a special led?
I thought for the flashing the capacicator c2 is responsible?
If the one you have is in a metal cover it’s not the same.
Sorry my mistake.
so one more question:
is it possible to change a unit in the curciut to have a permanent 12VDC output?
is it possible just to replace C2 by a wire for permanent output?
