I have succesfully soldered the minikit mk-112, and it seems to work. But after a few minutes playing one level I wondered how to select another level, turn on/off sound and so on… I tried a few buttons but didn’t really figure it out.
Yes, I did notice that! Of course… But it is a bit unclear… I tried it once more, and it seems that there are two times that the leds flash in some sort of a circle… 1st you select the sound on/of, than again the leds flash in some sort of a circle and you select the level…
Strange is though when it goes to sleep after inactivity, you resume it with which button? If you use button 1 you switch off the sound!
