MK 105 Signal Generator
I am about to buy the MK 105 Signal Generator Minikit. I was wondering, however, if the purpose I have in mind for the device fits the product. I want to use the signal generator to produce a continual sound trough an amplifier. I have checked the soldering manual and have not found an ‘audio output’, but i am confident this can be added.
I am quite new to soldering, and would like to know if this kit can be used for this purpose: producing a sawtooth/sine or other waveform to produce sounds trough an amplifier.
I hope you can help me!
There is an output, however, there is no connector supplied. Connector depends on your application.
Choose a suitable connector and connect it to the output. Google is your friend for connector pin-outs.
