While trying to fix stuck filament on my 2nd extruder… i missed the option “EXTRUDER2” in the MOVE AXIS (1mm) menu on the LCD menu.
Is this just missing or have i don’t something “special”?
Sadly it is an omission in the marlin firmware. We hope that the Marlin guys add this feature in the future. You can still extrude extruder 2 manually with Repetier host.
No problem, well… Not really, indeed with repetier or OctoPrint you can work around it.
Was just asking, as i updated the firmware back to H2. Maybe i did something wrong (it happens)
Thanks for the quick reply!
It seems that you’re not using the Vertex version of Repetier ((click to download it). It’s fully preprogrammed for Cura.
Only adjustments are:
[ul]
reducing the temperatures to 190°(PLA) or 220° (ABS).
Reducing the flow to 75%.
[/ul]
