Hey all
I’ve noticed many are using a mirror as a bed. Does this provide some advantage over plain glass?
Thanks.
Ian
Hey all
Thanks.
Ian
Not a difference in performance, the surface which you use to print on still is a glass one
A mirror surface might be advantageous to be able to watch if the print is turning out well, as you are able to see the print from below in many cases
Also, a mirror surface gives the printer a better look, mainly blocking the ugly looks of the heating bed
I may be wrong, but a bathroom mirror is more inclined to be tempered glass and can withstand the temperature changes better than a piece of ordinary glass?
Always use tempered glass
