After a good initial run with my Vertex, I seem to be having more and more problems lately
While still trying to get to the bottom of the recent problems I’ve been having with the nozzle maintaining temperature, today I am getting a MINTEMP error on the right-hand extruder.
I checked the thermistor was wired in correctly.
I tried a spare thermistor, same problem.
I verified the spare thermistor to be working by connecting it to the left extruder, where it correctly reads a temperature.
I swapped the extruder temperature sensor cables over on the motherboard. The right hand extruder now reads a temperature, and the left hand extruder does not.
As I know the thermistor is working, this would seem to indicate the problem is either with the sensor cable for the right hand extruder, or with the extruder PCB or connector.
Any other tests I can do to help isolate the problem so I can request the appropriate replacement part?
