Minimum environment temperature
I just moved my Vertex to what I hoped would be it’s final resting place in the cellar, but since moving it I’ve had problems with warping (fixed that with a decent raft), but also unsticking - I just ran a job to print 6 small figures and after about 15mm the whole construction came unstuck and was just moving around stuck to the nozzle.
Previously in the main part of the house I didn’t see these issues - the temperature there is over 20°C and in the cellar it’s 18°C. Would that explain these issues? I don’t think there are any draughts where the printer sits. I’m checking the z-calibration next to see if it’s moved - it does seem to vary.
Is you cellar particularly damp?
And yes if the nozzle is too far from the bed your print won’t stick.
It’s damper than the rest of the house - I’ll check. BTW I used brim not raft to solve the warping.
I would like the option to print the initial layers at a higher temperature to get better adhesion for the same reasons.
Sometimes the temp is down to 15C in the room where the printer is - it definitely doesn’t stick as well at those temps.
A heated bed and/or getting the nozzle very close to the surface.
I am still using the recommended ‘double-folded’ 80g paper test for the nozzle distance. I wondered if it would be better single-folded - it doesn’t seem to be a very precise method
I’m wondering why they don’t just give the specs. For my spark plugs i have a feeler gauge set, those would certainly work!
In the instructions they do mention ‘about 0.35mm’. I’ll have to get myself some feeler gauges…
They did this for the K8200 that was a hassle.
Besides everyone has printer paper available.
I think the paper is easier and you can always go up or down with it.
If you have feeler gauges you should try it.
Thanks, but ‘about 0.35’ isn’t really accurate is it? Same was with X and Y carrier which should be somewhere around 33.2cm (as i recall), which is hardly precise enough like we all know now. But i’m not really complaining, it is a kit after all and some ’figure-it-out-as-you-go’ is part of the building fun.
