Mini Kit MK129
Having successfully built many of your kits previously I now find a small problem with the crawling micro bug.
All works well on one speed but on the speed where sw2 connects T1 to T5, motor 1 pulses correctly while motor 2 runs at a full constant speed.
I have tested and looked for possible errors in construction but all seems well.
Can you please help, thank you
Still, there must be an assembly problem or defective component.
I have exactly the same problem - can’t work out what the issue is - Is it a specific component? One motor pulses (as it should) and the other is fully on (or off) and does not react to the speed pot.
Once again:
