using the voltage from manual (0,425V) I had missing steps on all steppers and the extruder stepper was not able at all, to move the filament. Then I discovered the hint (here) to increase voltage to 0.55V - that fixed the extruder stepper and z-axis (wich was the only stepper ok with 0,425V). X and Y still had missing steps. So I tried 0.6V - now X and Y worked reliable too.
So I started to print the cover.
Vibrations of the heatbed were so heavy, that 2 nuts dropped off. That happened at layer 3 or 4 and I decided not to care and continue printing. When the filament ended, I tried to insert a new one as described in the manual and I was really pissed off, when I noted, that it was not able to continue printing. Fuck!
That could habe been mentioned in the manual!
After disassembling the extruder, I realized, that replacing the filament is not a reliable task. It may work by occasion, if ever. In my case, the new filament slipped aside the old one, which did not move any further.
So I cleaned up everything, assembled the extruder again and started a new try after readjusting the heatbed.
The new result was completely disappointing and at 4th layer the created bubbles caused lost steps and messed up result.
With the new pla-filament, print result differs completely.
At 4th layer, the print was stil transparent
… and watching the hotend, it looks like it was printing a line and consuming the printed line on way back.
That results in lots of bubbles, which caused the print to fail completely.
What am I doing wrong?
I use 60° for heatbed, 190° for extruder and curaengine as slicer.
Any hint is appreciated.
