Hi
I’m looking into using the K8055 in monitoring the temperature in a fluid. The temperature range is 0-125C
Based on the temperature I’m going to activate different digital outputs. The problem is what kind of temperature sensor I need and how to connect it to the analog input to get good readings. I want the resolution to be as good as possible.
//Morten
