i was wondering if anyone have played with printing faster then the default max of 48mm/s ?
well after getting the temperature right, i print pretty much everything at max settings in the cura engine (48mm/s) and it looks fine.
the printer specs says 30-120mm/s but i havent tried to change anything yet (very new at this stuff) since i dont know if i can just change the max speed in the slicer config, or if i need to change alot of other things to get it to work
With a well tuned Vertex, you can easilly print at 120 mm/s but only with “basic” prints (no overhangs, not wanting too fine details).
The tip is to tune your slicer at lower speed then upgrading speed and temperature.
I’m pretty sure to be able to push it over 150 mm/s by tuning the “main flow” on printer’s panel while printing.
