Manual error
there is a mistake in the manual , when you have to solder the wires to the connectors, you read that orange, yellow and green must go with yellow and orange and you see on the image that it is with brown and red, wich one is the right one?
btw: it is image 65 of 93 at page 15 k8200.eu/manual/building/?c=015
The image is correct.
Manual will be corrected shortly.
Sorry for the inconvenience
I’m currently having fun making my printer.
Let me capture this thread…
k8200.eu/manual/building/?c=005
“Take a rod out of the bag labelled with 7. This rod should have a diameter of 10 mm (0.39”) and a length of 300 mm (11.8")."
This cannot be [color=#FF0000]10[/color] mm diameter, but [color=#0000FF]8[/color] mm!!! Apart from this that this bag had no number on it, at least in the version I got.
Edit:
also “Watch the colours closely” when wiring switches and thermistors, can be removed.
Thanks for this!
We will update the manual asap
Keep up the good work
Should be corrected now.
EN_016 Wiring the Z-Axis instructions state to cut the flat cable 3.94" when it should be 39.4".
