Which port does VM201 use for mail?
VM201 uses port 25.
It is important to note that the VM201 does not support any mail server that uses TLS or SSL to encrypt its connection. The port is the default SMTP port and can not be changed.
Note that many ISPs these days block outgoing connections on port 25 unless it is their own mail server where you have to authenticate.
