Mac OS Repetier - Slicer -paramiters for MAC SUPPORT K8400
Here are cura single head current parameter as starting point .rcp file from windows.
[print]
name = cura single head
defaultQuality = UGFdGjaROx9aQouMAZfWQqs4mQsUIfod
travelSpeedMin = 180
travelSpeedMax = 180
firstLayerSpeedMin = 15
firstLayerSpeedMax = 15
infillSpeedMin = 48
infillSpeedMax = 60
infillType = 0
innerPerimeterMin = 42
innerPerimeterMax = 48
outerPerimeterMin = 35
outerPerimeterMax = 48
printSpeedMin = 42
printSpeedMax = 48
gcodeFlavour = 0
retractionCombing = True
multiVolumeOverlap = 0
cutOffObjectBottom = 0
shellThickness = 0.7
infillTopBottomThickness = 0.3
infillDensityPercent = 20
supportType = 0
platformAdhesion = 0
dualExtrusion = 0
wipeAndPrimeTower = False
oozeShield = False
enableRetraction = True
retractionSpeed = 70
retractionDistance = 9
multiExtruderSwitchAmount = 9
startGCode = “”"
G28 ; Home extruder
G1 Z5 F{Z_TRAVEL_SPEED}
G1 Z0 F{Z_TRAVEL_SPEED}
M106 S165 ; Turn on fan
G90 ; Absolute positioning
M82 ; Extruder in absolute mode
; Activate all used extruder
{IF_EXT0}M104 T0 S{TEMP0}
{IF_EXT1}M104 T1 S{TEMP1}
G92 E0 ; Reset extruder position
; Wait for all used extruders to reach temperature
{IF_EXT0}M109 T0 S{TEMP0}
{IF_EXT1}M109 T1 S{TEMP1}
{IF_EXT0}T0
{IF_EXT1}T1
M83
G1 E10 F100
M82
M117 Vertex is printing
G1 F1000 Z5
endGCode = “”"
M107 ; Turn off fan
; Disable all extruder
G91 ; Relative positioning
{IF_EXT0}T0
{IF_EXT0}G1 E-1 ; Reduce filament pressure
M104 T0 S0
{IF_EXT1}T1
{IF_EXT1}G1 E-1 ; Reduce filament pressure
M104 T1 S0
M140 S0 ; Disable heated bed
M84 ; Turn steppers off
T0
T1
T0
preSwitchExtruderCode =
postSwitchExtruderCode =
wipeAndPrimeTowerVolume = 5
retractionMinimumTravel = 0.1
minimumExtrusionBeforeRetract = 0.02
zhop = 0
skirtLineCount = 3
skirtDistance = 3
skirtMinimumLength = 150
solidInfillTop = True
solidInfillBottom = True
infillOverlapPercent = 0
supportStructureType = 0
supportOverhang = 5
supportFillPercent = 20
supportDistanceXY = 0.8
supportDistanceZ = 0.1
supportExtruder = -1
spiralizeOuterContour = False
brimWidth = 7
raftExtraMargin = 5
raftLineSpacing = 1
raftBaseThickness = 0.3
raftBaseWidth = 0.7
raftInterfaceThickness = 0.2
raftInterfaceLineWidth = 0.2
raftAirGap = 0
raftAirGapLayer0 = 0
raftSurfaceLayer = 1
fixCombineEverythingA = True
fixCombineEverythingB = False
fixKeepOpenFaces = False
fixExtensiveStitching = False
fanFullAtHeight = 0
minimumSpeed = 10
coolHeadLift = True
numQuality = 1
nozzleDiameter = 0
[quality_0]
name = 0.1mm
signature = UGFdGjaROx9aQouMAZfWQqs4mQsUIfod
layerHeight = 0.105
firstLayerHeight = 0.2
layer0widthPercent = 100
i’m very cautious with using these settings as you have never used them yourself. Where did you find these settings? How are they different from the 1.1.7 defaults?
It collection of parameters from this post about Vertex Curaengine.
But only the once I could match. So finetuning is still needed.
viewtopic.php?f=61&t=13176#p57887
viewtopic.php?f=61&t=13176#p57887[/quote]
Do NOT use these settings. As described in that post they were NOT the correct ones.
Do NOT use these settings. As described in that post they were NOT the correct ones.[/quote]
I have now removed the old paramiter set and replaced them with Cura set from latest Vertex slicer
[print]
infillSpeedMin = 48
infillSpeedMax = 60
infillType = 0
printSpeedMin = 42
printSpeedMax = 48
gcodeFlavour = 0
supportType = 0
dualExtrusion = 0
oozeShield = False
startGCode = “”"
G28 ; Home extruder
{IF_EXT0}T0
{IF_EXT1}T1
M83
G1 E10 F100
M82
G1 F1000 Z5
endGCode = “”"
M107 ; Turn off fan
{IF_EXT0}T0
M104 T0 S0
{IF_EXT1}T1
M104 T1 S0
T0
T1
T0
zhop = 0
skirtLineCount = 3
skirtDistance = 3
supportOverhang = 5
brimWidth = 7
raftExtraMargin = 5
raftLineSpacing = 1
raftBaseWidth = 0.7
raftAirGap = 0
fanFullAtHeight = 0
minimumSpeed = 10
coolHeadLift = True
numQuality = 1
nozzleDiameter = 0
[quality_0]
name = 0.1mm
layerHeight = 0.105
Here are results of manual matching Cura parameters to MAC Slicer . Still not tested due to printer waiting for parts.
[size=150]WARNING !!! Not Tested yet
[/size]
Some challenges:
Have not fully been able map some of these Extruder retrack paramiters referred below
viewtopic.php?f=61&t=13124#p57580
Invert Z ? How to do with Slic3r ?
well here are current best values for your feedback:
generated by Slic3r 1.1.7 on Wed Dec 24 21:46:23 2014
avoid_crossing_perimeters = 0
bed_size = 200,200
bed_temperature = 0
bottom_solid_layers = 3
bridge_acceleration = 0
bridge_fan_speed = 100
bridge_flow_ratio = 1
bridge_speed = 60
brim_width = 7
complete_objects = 0
cooling = 0
default_acceleration = 0
disable_fan_first_layers = 0
dont_support_bridges = 1
duplicate_distance = 6
end_gcode = M107 ; Turn off fan\n; Disable all extruder\nG91 ; Relative positioning\n{IF_EXT0}T0\n{IF_EXT0}G1 E-1 ; Reduce filament pressure\nM104 T0 S0\n{IF_EXT1}T1\n{IF_EXT1}G1 E-1 ; Reduce filament pressure\nM104 T1 S0\nG90 ; Absolute positioning\nG92 E0 ; Reset extruder position\nM140 S0 ; Disable heated bed\nM84 ; Turn steppers off\nT0\nT1\nT0
external_perimeter_speed = 70%
external_perimeters_first = 0
extra_perimeters = 1
extruder_clearance_height = 20
extruder_clearance_radius = 20
extruder_offset = 0x0
extrusion_axis = E
extrusion_multiplier = 90
extrusion_width = 0
fan_always_on = 1
fan_below_layer_time = 60
filament_diameter = 1.75,75
fill_angle = 45
fill_density = 30%
fill_pattern = honeycomb
first_layer_acceleration = 0
first_layer_bed_temperature = 0
first_layer_extrusion_width = 200%
first_layer_height = 0.2
first_layer_speed = 15
first_layer_temperature = 210
g0 = 0
gap_fill_speed = 20
gcode_arcs = 0
gcode_comments = 0
gcode_flavor = reprap
infill_acceleration = 0
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0
infill_first = 0
infill_only_where_needed = 0
infill_speed = 60
interface_shells = 0
layer_gcode =
layer_height = 0.105
max_fan_speed = 100
min_fan_speed = 100
min_print_speed = 10
min_skirt_length = 150
notes =
nozzle_diameter = 0.35
only_retract_when_crossing_perimeters = 1
ooze_prevention = 0
output_filename_format = [input_filename_base].gcode
overhangs = 1
perimeter_acceleration = 0
perimeter_extruder = 1
perimeter_extrusion_width = 0
perimeter_speed = 30
perimeters = 3
post_process =
print_center = 100,100
raft_layers = 0
resolution = 0
retract_before_travel = 2
retract_layer_change = 1
retract_length = 1
retract_length_toolchange = 9
retract_lift = 0
retract_restart_extra = 0
retract_restart_extra_toolchange = 0
retract_speed = 40
seam_position = aligned
skirt_distance = 3
skirt_height = 1
skirts = 1
slowdown_below_layer_time = 30
small_perimeter_speed = 30
solid_fill_pattern = rectilinear
solid_infill_below_area = 70
solid_infill_every_layers = 0
solid_infill_extrusion_width = 0
solid_infill_speed = 60
spiral_vase = 0
standby_temperature_delta = -5
start_gcode = G28 ; Home extruder\nG1 Z5 F{Z_TRAVEL_SPEED}\nG1 Z0 F{Z_TRAVEL_SPEED}\nM106 S165 ; Turn on fan\nG90 ; Absolute positioning\nM82 ; Extruder in absolute mode\n; Activate all used extruder\n{IF_EXT0}M104 T0 S{TEMP0}\n{IF_EXT1}M104 T1 S{TEMP1}\nG92 E0 ; Reset extruder position\n; Wait for all used extruders to reach temperature\n{IF_EXT0}M109 T0 S{TEMP0}\n{IF_EXT1}M109 T1 S{TEMP1}\n{IF_EXT0}T0\n{IF_EXT1}T1\nM83\nG1 E10 F100\nM82\nG92 E0 ; Reset extruder position\nM117 Vertex is printing\nG1 F1000 Z5
support_material = 0
support_material_angle = 0
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_extrusion_width = 0
support_material_interface_extruder = 1
support_material_interface_layers = 1
support_material_interface_spacing = 0
support_material_interface_speed = 100%
support_material_pattern = rectilinear
support_material_spacing = 1
support_material_speed = 60
support_material_threshold = 5
temperature = 210
thin_walls = 1
threads = 2
toolchange_gcode =
top_infill_extrusion_width = 0
top_solid_infill_speed = 50
top_solid_layers = 3
travel_speed = 130
use_firmware_retraction = 0
use_relative_e_distances = 0
vibration_limit = 0
wipe = 0
z_offset = 0
that’s fine I guess. There isn’t a big blue “Vertex 3D Printer” text. I can live with that. I can connect to the printer. I can home the axes under manual control. I can move the bed down to 100 mm, but not more than that (probably because the printer shape under printer settings is set to 100 mm???). The home 70-462
position is 200/200/0 as shown on the LCD but 0/0/0 as shown in repetier. When I try to move the Y-axis -10 mm in repetier it actually does this. But repetier still shows 0/0/0 whereas the LCD shows 200/190/0. And after the initial -10 mm it will not move anymore. I can always move the axis manually using the rotary encoder/LCD. Maybe I need to align the X/Y rods? Just strange that it always works using the LCD/rotary enoder.
