is it possible to generate a sine- wave (Or better: A customer created wave) at a frequency below 11mHz?
I’m new to the PCGU 1000 and have just made first steps using the provided software.
Reason: I need a wave that need round about 5 minutes for a complete cycle (3.3 mHz)
In sweep mode it is possible to produce an output frequency as low as 0.0001Hz (0.1mHz).
Set the Start and Stop frequencies (in your case set both to 0.0033) and click Start Sweep button to output sine waveform.
You may also use custom waveform:
Click the MORE FUNCT. button.
Click Sweep button.
Check the Sweep selected waveform check box.
Click LIB button.
Locate and open the custom waveform file (normally located in the \lib subfolder).
Click Sweep button.
Click Start Sweep button.
