Lost of the zero point
My problem, that the printing Y slips in a direction, at all printing after about 2 minutes.
What kind of software settings wrong? Is the problem in the Slic3r settings, or somewhere else?
Thank you for your help.
Give more info on your printer config.
What did you set the Stepper drivers to ? 0.425 or 0.55v?
What is your max jerk value set to?
Are your belts tight?
Did you check the screw that holds the pulley on the motor?
Do all of the bearings spin freely?
Thanks for your answer.
The belts are enough tight, and the mechanical things on the printer are OK.
A tryed use the printer with reptirer host 0.84 and 0.95. I upgraded firmware.
The software i tryed the used with the specifications.
We are switching the X and Y directions cables on the control panel, and the error in the Y direction again.
The stepper driver to 0.425
Thanks for your help.
Set your stepper drivers to 0.55v to prevent losing steps.
That should make the issue disappear.
