I am testing my vertex printer after monting it. it is not possible to load the filament with the described procedureon your web site. in fact the loading never start because the temperature of the nozzle is at a maximum temperature of 232 °C!.. it does not reach the 254°C as requested and also the step motor never Start.
However i have changed the parameters (aither in “setting” menu, or on the repetier software) for the fan speed i decreased to 100. So i succeeded to load the filament “manually” with the repetier.
But this fan speed parameter is not maintained in the load filament procedure.
do you have answer or solution for this issue
Thanks for your reply
