Printed with Vertex 3d Printer (K8400). From black and white 2d photo converted in Cura to 3d model.
Size 20cmx12cmx0.15cm , printed with Repetier-Host Cura slicer 0.1 layer height. Printing took four hours.
And some single, dual colour printed objects.
Pla Innofil Silver and Magenta.
Looking very nice!
Hello NIYOKI ,
What software 2D to 3D did you use for Lithophanes?
very good work ! and thank you for your reply.
jean-michel
I used Cura from Ultimaker Homepage. You need a photo file like *.jpeg (in gray or black & White works good). If you open a photo file in Cura it will ask some preferences for converting to 3d file. I changed for example height from 10 mm to 1.5 mm. After converting done just save as *.stl file go to Repetier-host and print it. But I was surprised such a good Quality print from Vertex and this effect what Cura delivered.
ok many tks for your answer!!
jean-michel
Eiffel Tower printed 0.1 layer quality, brim and supports to the print bed, printed in 14 hours.
Statue of Liberty 0.1 layer quality, supports everywhere, printed in 13 hours 30 minutes.
Used Repetier-Host with Cura slicer engine. Both objects has 195 mm height.
very nice job
I tried last night but forgetting to put the infill 0% !!
I’ll try again today
Very nice!
Really nice prints you have there
Great prints - difficult ones too.
hello niyoki
I come to ask you some questions, I am not able to get good results. Would you give me the important parameters to be modified for printing in repetier host, as infill, shell thickness, top and bottom thicknesss etc., to succeed
Forgive me for bothering you
thank you very much
jean-michel
[quote=“KERGUELEN”]hello niyoki
thank you very much
jean-michel[/quote]
Hello Kerguelen,
sorry for my late answer can I send you my Repetier-Host Profile files for my Settings? Or can someone tell me how to put this Profile files for Repetier-Host hier in Post?
hello, no problem
you could use dropbox and put your link in a post
thanks
jeanmichel
[quote=“KERGUELEN”]hello, no problem
thanks
jeanmichel[/quote]
I try. Please don’t forget to save your profile settings before loading my settings. Here are the links for Dropbox files (01 means 0,1 mm Layerheight):
https://www.dropbox.com/s/j8wnt0uec9lwmg1/RepetierPLA.rcf?dl=0
https://www.dropbox.com/s/cc3eudoykmjnamb/RepetierABS.rcf?dl=0
https://www.dropbox.com/s/gla7iqcko4hoahy/SingleRepetier01.rcp?dl=0
https://www.dropbox.com/s/uiufco9xnw2w5h1/SingleRepetier02.rcp?dl=0
https://www.dropbox.com/s/9xhlkyftn0xefv7/DualRepetier01.rcp?dl=0
https://www.dropbox.com/s/nf4c3pycd3voc28/DualRepetier02.rcp?dl=0
