Hello, is it possible to let the K8088 work together with amBX Starter Kit
The aim is ambi light in my room ![]()
probably the signal from the amBX kit is PWM controlled, can I get this into the K8088 ![]()
If the signal is not PWM, can I use than transistor’s or fet’s, that are connected with the led’s on the amBX bord, and with my RGB rails (12V, approximately 3A) ?
Some Pictures:
http://yfrog.com/2oimg2406bj <= This is the Main controller from above
http://yfrog.com/joimg2407dj <= This is the Main controller from underneath
http://yfrog.com/f7img2408j <= This is the LED unit from above
http://yfrog.com/9fimg2409fj <= This is the LED unit from underneath
http://yfrog.com/giimg2410j <= The main controller and the LED unit connected with each other
http://yfrog.com/j4rgbrailscontrollerp <= This is how It works now
EDIT: the lichtcomputer is a K8044, and the RGB controller a K8088 ![]()
If there is information needed, you can ask me, but I don’t now much over amBX, because there is no much on the web ![]()
Chris Smit
