LED not illuminating on MK125
I Have just made a MK125. I checked everything was O.K. and powered up. The LED didn’t light up, despite covering the LDR. I can hear the relay clicking when I turn the pot. I didn’t have a voltage load to the relay though. Would this be the reason? I have made one in the past and the LED on that one does illuminate under a 6 volt load.
Since you can hear the relay it sounds like the LED is in backwards
O.K., Thanks, but I’m sure it is the right way round. I will check again and let you know.
You should look at the pads make sure they were not over heated and broken.
O.K., Thanks, but I’m sure it is the right way round. I will check again and let you know.[/quote]
Yes, You were right. I can’t believe I did that. Everything O.K. now. Much appreciated. Best regards.
Glad to hear it’s working for you.
Enjoy!
