LCD reboots everytime I try to heat up the extruder manually
I can’t get the printer heated up, It doesn’t work through the Repetier-Host anymore, it just stopped, so I tried to do it manually through the LCD screen, everytime I do, it just reboots the screen and there’s a light on the power supply that’s blinking, is there a way to reset the power supply, I tried resetting the board, but it doesn’t do anything, the connection to the board is ok too, so what happened, did I fry the power supply somehow?
It’s the k8400 printer
You wrote: “It doesn’t work through the Repetier-Host anymore,”, so this means some times before it worked correct. What has happened in between?
I’ve taken a closer look at the board underneath, it looks like somehow I bent the heater connection, I moved my printer a couple of times and there must have been something underneath it the last time that I didn’t notice, I can’t see, but on the inside of the connector 1 of the pins must be loose while still sticking to the plastic on the main board, I can still hook up the wire connector to the pins on the board even though there bent, but no power going through, it tries though, but just reboots the screen, I might try to pull the plastic from the pins, don’t know yet and see if all I need to do is solder it.
