I just finished the 3d printer vertex k8400 printer assembly. The problem is: the LCD panel does not show anything (lit background, no messages). This problem as a workaround: tilting the printer (75 degrees at least) solve the problem: you switch on the printer, the right message show up on the lcd panel. I found the flat cable connector a little loose but even pushing it towards the pcb does not change things: the tilt works, any other move no. Did you find something like this?
After a little work on connections (nothing really seemed wrong - only some cable loose) the printer power cycle works everytime and the lcd shows the right messages but…
NO USB CONNECTION AVAILABLE: no matter what o.s. I use (windows xp 32 bit, windows 7 64 bit, linux ubuntu, linux mageia), no matter what cable I use (short lenght, standard lenght, original…) the pcb of the printer is not recognized. The usb port of the pc powers the pcb and the lcd on, leds on the pcb cycles but nothing happens on the side of the pc. Device manager shows “unknown device”. The usbview software shows ANYTHING on the port. The lsusb command in a linux terminal does the same: NO DEVICE.
It seems like the USB connection does not work AT LEAST.
