I have finally got my 3d printer running on ABS. I have a small problem though. Every couple of layers the 3d printer decides to make a wider layer on the model being printed. They look like ridges. I dont know what to do to fix it up in order to make a perfectly smooth model.
Another issue that I have is that some models I cant print because the supports are not placed there, and if they are, they are hard to remove. Does anyone have a set of settings I can use.
I am currently using the K8200 printer
Bed heated to 60 degrees with tape and glue (so the abs doesnt warp)
Extruder temp is at 250 degrees
feedrate at 100.
I was wondering how you address the vertical waves/lines/bumps on the 3d print. I upgraded my flexible coupler and the prints are far better. Almost as good as yours. Do you use abs or pla? Also can you attach your ini file for your pla?
I just have heaps of those vertical bumps on my finish prints… if I can fix this the prints would be perfect. Maybe it is something in the slic3r settings, i noticed you have some very slight ones in the corners, but nothing like mine. I have attached a photo for you to have a look.
I’m printing with PLA (Brand: Siridi), I’ll attach my config file for Slic3r tonight (I’m at work at the moment :P).
My printer has the stock hotend, no other modifications other than the upgraded Z-axis.
[quote]I was wondering how you address the vertical waves/lines/bumps on the 3d print. I upgraded my flexible coupler and the prints are far better. Almost as good as yours. Do you use abs or pla? Also can you attach your ini file for your pla?
I just have heaps of those vertical bumps on my finish prints… if I can fix this the prints would be perfect. Maybe it is something in the slic3r settings, i noticed you have some very slight ones in the corners, but nothing like mine. I have attached a photo for you to have a look.[/quote]
Looks like it could be shadows from the infill:
To prove: print bottom part with no infill.
If so, to cure: having more perimeters or thicker shell will help.
P.S. Tighten the top nut on the Z axis threaded rod slightly so the flex coupler is slightly under tension. That might get rid of the odd horizontal layers you have.
no they are not… they are random widths. Some of them are approx 5 mm… but if i adjust the acceleration to 80mm per second in slic3r it softens the lines… but they are still there.
