Layer strength with ABS
hello
after fitting a heatbed, i can now start to work properly with ABS.
BUT i can seem to find the correct temperature, i tried doing the same as i did with PLA (0,35mm vertical tower with changing temperature every 50 layers) with the PLA there was a clear visual change in the texture and the shine of the plastic. but i cant seem to get that on the ABS, it looks more or less the same from 160 to 250.
the print looks fine, nice smooth velvet finish with no artifacts, but it seems no matter what temperature i try, it turns out britte. it seems like the layers doesnt fuse together properly.
anyone had this problem, and know what i am doing wrong ?
