Following my other thread about bridging…I’m also having some kind of layer shifting. But what bothers the most is the repetivity of it. If I van call it that…
My pics show better my problem.
My part is a low poly mario from youmagine.
If I could measure it, pretty sure they all have the same height.
Z Wobble? The shifting is barely noticeable.
Yes, that’s Z wobble. Could try playing around the flexible connector, but I’m not convinced that makes a huge difference.
You are right, it’s already aligned as per wiki.
Is it normal the bed moving with printhead? I mean a very very very almost not perceptible move.
Already applied the top bearing mod btw
I think there’s always a bit of movement. I’ve noticed this problem has got worse over time, so I suspect I need to go round and tighten up some nuts. But I’m not sure how to eradicate it completely.
…or the frame has lost some of it’s stiffness.
My printer is stopped for some days now because I think the printhead is clogged ( it’s very hard to feed plastic even if hand feeding it ). So I need to disassemble it and clean it ( again… ). This week and next I’ll have a look at both issues.
