I expected that my printer would sometimes make misprints, but i didn´t expect the succesrate to be less than 10%, I am having huge problems with offsetting/ layer shifting and haven´t produced any “successful prints” since the very first thing i made(a low-poly totodile) and a 1,5cm^3 test-cube that i since haven´t been able to replicate.
During printing, especially when the printhead is attempting to move fast, the printer will produce a loud rumbling noise, after which the print will be offset, usually to the left.
A video of me manually controlling the printer:
https://dl.dropboxusercontent.com/u/48208874/VERTEX%20Settings/20141214_123929.mp4
Attempt to print another test-cube:
https://dl.dropboxusercontent.com/u/48208874/VERTEX%20Settings/20141214_124517.mp4
I didn´t bother to finish the print, but heres how it looked and how it was supposed to look:
I have de-assembled and re-assembled step 16-17 twice now, putting alot of attention into making the
pulleys and rods as perpendicular and parallel as possible, but i am not sure it is enough.
I have oiled the rods again, updated the firmware to M1, V1.1,H1 - restored the failsafe and stored in memory, i have tightened all the pulleys made sure the motors are securely fastened and their belts as tight as possible, and made sure the printhead is securely assembled.
…and i have made sure the printer stands on even ground with a spirit level.
The problem is NOT the filament being to tight, I have mades sure there is slack between the spool and the extruder, and the spool can move freely.
I have notices some “black dust" on top of two of the motors, i guess this is either from the belt or the bearing clamps, does this perhaps mean i have tightened something too much? - i have made sure that the pulleys and bearing clamps can move effortlessly up and down the rods BTW.
The 4 nuts in the back of the bearing clamps, seems to unwind when the jerking occurs - maybe i should use locking nuts instead?
NOTE, i am missing 2 clasps that hold the buildplate onto the Z-axis, I was missing 2 4M-3mm screws in the kit
- and replacements are on their way here, but I doubt that is what is causing the problem - the buildplate seems to stay put during printing with no problems.
I haven´t checked the the temperature of the 1.5A driver boards - as suggested in the FAQ, since I can hear it is a mechanical problem, so I don´t think they are the problem, but please tell me if you disagree with that assessment.
Also, the text on the display is very dim, is there a potentiometer somewhere i can adjust the contrast with?
Lastly, this may be due to the exact same thing, but circles aren´t coming out circular but rather oval in shape.
I am running both Windows 7 and Mac OS X on laptop, but i would like to cast my vote to have a mac version of the software released, or just a document detailing how to get the vertex printer settings working with the repetier host version on the mac.
It has come to the point where i am just trying to move the pulleys and rods - the printhead sit on, randomly back and forth, with the hope of finding a position that is correct enough - but to no avail.
on a positive note, I am happy with the 2 successful print i have produced so far, i am very pleased with the details at 0,1mm and looking forward to working with 0,005mm.
I really hope someone in here can help me, since I am at my wits end here.
Thanks.
P.S. I am sorry if the text is a little unclear, but english is not my vernacular.
