Latest repetier host version just won't connect
at first I used the same repetier version which was recommended by the get started tutorial and that worked. Now I installed the latest repetier host, the damned thing just won’t connect to my printer. I can connect via that repetier server thing, but I cannot control my printer if I am connected like that. settings are all correct, baudrate at 250000 com 13. Just nothing.
Am I misssing something or do I need to flash new firmware in the printer or must I take my old software back?
Did u uncheck the check box Use ping pong communication … ?
stop server perhaps? on top of the repetier
Check in the printer setting in Repetier.
Try this version of Repetier Host.
http://www.k8200.eu/downloads/files/downloads/setup_repetierhost_k8200_0_95f.zip
Correct Com Port
Baud rate 250000
Reset on Connect = Disabled.
I indeed had to manually stop the server. After that I could connect and control my printer, thank you.
