Larger cooling fan for bed - options?
Hey all
I’ve made a fan duct that I’m happy with but I’m thinking the stock fan could be slightly larger.
Any thoughts on how big a fan could be used before the controller needs upgrading?
Thanks in advance.
[quote=“stratafied”]Hey all
Thanks in advance.[/quote]
What size do you want to use?
I think a 40X40 fan should be more than sufficient…
[quote=“ichbinsnur”]What size do you want to use?
I think a 40X40 fan should be more than sufficient…[/quote]
The existing fan is a 40x40x10. I’ve seen similar fans that are rated at 12V, 80mA, 0.16m^3/m
I’d like to use one that is 40x40x20 - 12V, 100mA, 0.2m^3/m
(around 1/3 more airflow?)
[quote=“stratafied”][quote=“ichbinsnur”]What size do you want to use?
(around 1/3 more airflow?)[/quote]
if it draws only 100mA you should be golden.
