Lamp / Relay switching vith variable intervals
Hi, can anyone please advise me which kit to use for following:
I want to switch a a relay, (or in the end a number of turnindicator car/motorcycle lamps with total of 12V-250W/20A).
The idea of what I want is: At moment of activating a switch I want the relay (or lamps) to switch with the following pattern;
350 msec High
175 msec Low
175 msec High
175 msec Low
175 msec High
175 msec Low
350 msec High
175 msec Low
175 msec High
175 msec Low
175 msec High
175 msec Low
350 msec High
and this continuing for as long as the switch is “ON”. As soon as the switch is “OFF” the relay (or lamps) show fall back to “Low”.
Bytheway; the times are indicational, if there is an excisting kit with some different timings I’m also interested. Thanx in advance !!
Sorry, this timing is so complex that it calls for a custom circuit or firmware.
If you are capable of programming a PIC, you could get the K8015 or MK188 and write new firmware which does exactly that.
