Ksr10 problem
hi guys,
i have assembled the ksr10 but now i have the following problem:
when i am moving the entire arm upwards or downwards (m4 on the remote) the arm will just fall down from one point on. if i want to lift it up again i have to push the lever for a short while until the mechanics “catch up” onto the uncontrolled fall. then it works just fine for a few seconds. but if i continue to move the arm in the same direction i will reach a similar trigger point on the opposite side where the arm will fall down as well. to get it back up i will have to do the same.
anybody having any idea on what i did wrong assembling it? or is it just a broken one and i have to send it back for replacement?
thx
We from the projects dept. haven’t any expirience with this robot kit. If there is a hardware problem with it, you should best contact your dealer.
