Hi, I mounted the robot arm kit as explained on your instructions, but the control doesn’t work correctly.
All the 5 electric motors work fine, only they work only on one direction.
If I reverse the contacts, motors work in the other direction.
It seems like half of the circuit is not correctly connected to the batteries.
I checked with a tester all connections, and all seems fine to me (no broken cables).
Could be possible that something’s missing in the electrical board inside the robot?
I compared the electrical board with the electrical schema design, but I don’t see anything wrong.
Could someone help me? Did someone else have the same problem?
PS When I bought the kit from the store in Brussels, I didn’t found any instructions inside the box, just the CD for the USB (with no USB cables). I downloaded he instructions from your web site, but I’m wondering if the model is the same.
Thank you for your help.
