KIT8050 IR-receiver as audio source selector
I’m planning on using the KIT8050 15ch IR-receiver as input selector driving signal relays for an audio project.
The assiciated 15ch remote will be used.
However, I can not figure out from the available info if it is possible to jump from one selected channel to any
of the other channels with only one ch active at a time. (for ex. from ch 7 to ch 13)
I don’t want 2 channels active at the same time. There are a mode called “rotary” but does this mean you need to
switch channels from 1 to 15 in a straight sequence ? or can you jump between different channels directly.
Thannks in advance / Mattias
You can jump from one output to another one, it does not necessarily have to be in sequence.
OK, Thanks.
I’ll get a 8050 kit + a remote and try it out.
Regards / Mattias
