Kit 7200
i have found an velleman kit k7200 but one of the components are missing
it is the 50 cm resistance wire where can y find this ? or can velleman still have this ?
thank you
Unfortunately this item has been obsolete for a very long time and no longer available.
Each wire should have a resistance of 0.08 ohm. Maybe you can find a replacement online?
why is it still visible online ?
If you look in the upper right corner you will see removed from our assortment
yes i now but if it is obsolete for a very long time and no longer available
why still leaving this on the website ?
I can’t answer that.
Just a guess.
Under downloads you can find the assembly manual
I have a k7200 but the voltage is between 4.8v and 20v instead of 0-30v.
Any idea what it can be?
Or a direction where to look or search for?
thx in advance !
btw: that’s he real voltage, checked with another meter and is apparantly always been that way
This can be anything, but most likely an assembly error.
Solving this from a distance is quite impossible, we need to be able to check your unit.
If you wish, you can still return it for inspection/repair, we are still able to service it.
Dear apeiros,
These products remain on our website so everyone is able to retrieve the necessary info (specs, features and downloads).
Some shops might still be selling these products after we remove it from our assortment, for our and their customers we keep the information about the product available.
I know this might cause confusion, we will certainly take your comments and confusion into account on future improvements for the website.
If you have any other comments regarding the website(s), we would be happy to hear about it on webmaster at velleman dot be.
