I am trying to use KISSlicer (V 1.1.0.14, May 2013) with a K8200 under Repetier (V 0.84).
I take a .stl file that works perfectly well under Slic3r and generate the gcode, which then I load into Repetier. However, in the 3D viewer all I get is only a few blue lines (sometimes not even that). The lines appear to be on the “floor” and outside the cage.
How should I configure both programs to work together?
it’s tricky - practically none of the defaults are correct for the k8200.
I now use KISslicer (but separately from Repetier - you can’t seem to call it directly from Repetier). I still use Repetier to check the slicing, it has a good GCODE viewer. I can view the gcode from KISslicer without problems with this set up.
