K8800 - Stops mid print
Hello, i am fairly new to the 3D printing world but i have a problem with my K8800 3D printer.
After some time my printer stops printing and unloads it self and i cant find the solution.
Does anyone know the solution to this?
Hello @thegoodbeast ,
Solution:
Disconnect the Filament Runout Sensor if it gives too many false alarms.
This often occurs especially with a full or almost empty spool of Filament.
Due to: vibrations on the sensor, filament not perfect everywhere 1.75 mm thick (tolerances).
If you disconnect this sensor, you still retain the “Filament Change In Mid Print” function.
See info manual:
Velleman Technical Service
