Desperately looking for suggestions that may help me solve a printing issue, where after hours of printing the layers suddenly no longer interconnect. See photo of the two disconnected layers, where the loose part is turned upside-down to show what that first ‘loose’ layer looks like.
Print result: https://1drv.ms/u/s!AjTf8l1Pbyej1TgSK7nDvu33oick?e=CwoJnx
Slicer: https://1drv.ms/u/s!AjTf8l1Pbyej1Tlb01fOATILSzm1?e=GOlXVp
Slicer with support: https://1drv.ms/u/s!AjTf8l1Pbyej1Toylu6AXSTBx59K?e=c1soYg
My first suspect is that after ‘ironing’ part of the last ‘good’ layer, the non-ironed surface cools off too much for the next layer to ’stick’. But then, if this IS the actual cause, I wonder:
- why is ironing being allowed for non-bottom and non-top surfaces?
- why does this happen after ironing the first layer?
- what could I do about it
That said, maybe I should rethink for an entirely other cause for this to happen.
Any help or suggestion towards resolving this is highly appreciated.
Slicer: Ultimaker Cura 4.8.0 on Mac OSX 11.1 (Big Sur)
Printer: Vertex K8800
Material: PLA (Velleman)
Temp: 195C
Layer height: 0,1mm
Ironing: on
Ironing pattern: Concentric
Ironing line spacing: 0,1 mm (default)
Ironing inset: 0,0825 mm (default)
Ironing speed: 23,3333 (default)
Print speed: 35 mm
Print cooling: enable with fan at 40%
Support structures on ‘everywhere’, overhang at 40 degrees
