I’ve just gone into this wonderfull 3DPrint’s world , with my new Nano Print Vertex !!!
Building it was very pleasant ; and good to understand the working of the 3dPrint and be able to maintain it.
So, I have a problem !
Since the beginning my Z axis is not working good.
I try various adjustments with the spring on the rod. Because if it’s to strong, the motor can’t turn it up ; if it’s to light the print don’t work good (the 3th slide is in the same high of the first and the second… the axe Z don’t go up)
I use a good silicon lubrification of all the axis.
I’ve notice too that the rod is a little bit bent.
This thing already happen to someone here ?
I can’t print anything with this problem, so, I may change the rod / nut / sprint to have something more optimal. Do someone have done that here ?
Some advices ?
Thanks to your read.
Boby
