Hello everyone,
When the print starts with his first layer of filament. It starts realy high even it says on the dislpay it is 0,20 mm. It starts around 2 mm of z-axis height.
I never had this problem before.
The bed is corret leveld because when I use the auto home function there is just enough space for the paper that is double folded.
I tried several prints from differt slicers so that can’t be the problem.
Someone knows a solution?
Regards Niels
