Probably a bad connector resulted in a high resistance between the connection. This leads to high temperatures inside the connector and results in the issue you have. This is normally under warranty. Could you post a picture of the connector on the board when it’s disconnected (so only the male part). To check if the board also has to be replaced.
Either way you can start by opening a support ticket here:
