when I completely assembled the 3d printer and wanted to test the movement of all of the axis, I noticed that the y-axis only turns in one direction.
I have tried/checked the following:
- switched the stepper driver board with a board from a working axis (no effect)
- checked if the y stepper motor worked on other axis (it did)
- checked for broken wires/connectors between the driver board pins (1A 2A 1B 2B) and the connector at the end of the wire near the stepper motor (no broken connections).
I noticed that when I drive the y-motor in the working direction, the light next to the stepper driver board lights up brightly. When I turn the motor in the non-working directly however, the light next to the driver board is very dim and pulses brightly every so often.
