K8400 Update problem
[quote=“Örni”]Hi
The Version is 1.0.6.[/quote]
Try downloading the firmware files again with firefox.
Then unpack them to a new directory and open the marlin.ino from there.
cheers,
Christian
Hi Christian
I tryed like you told me to, but the same Problem like bevor. Errors when the Programm is compiling.
I don’t know what to do
regard’s
werner
Just to be sure.
You unzipped them like ichbinsnur suggested right?
yes i unziped it, like you sayed
Are you loading the Marlino.ino?
For the board you are selecting Arduino2560 or Mega ADK?
I opened the Merlin.ino file inside the merlin Programm.then wen comiling the Programm i have all the errores.
I have the Mega 2560 and it is selected on Tools Boards, Arduino Mega 2560 or Mega ADK
Ok I’m running out of ideas I hope ichbinsnur has some.
What is the error you are seeing?
I don’t know what the error is so this is just a shot in the dark.
Try looking at this thread.
http://forum.velleman.eu/viewtopic.php?f=60&t=13916&hilit=solved&start=15
The last entry was.
"I solved my firmware upgrade problem. I changed under com port settings advanced tab suspend to 3600 sec. After this change firmware upgrade ended with “Done Upgrade AVRDDUDE thank you”
I hope it helps.
[quote=“Wrong Way”]I don’t know what the error is so this is just a shot in the dark.
The last entry was.
I hope it helps.[/quote]
I think he can’t get it to compile at all, so he won’t be able to upload it …
Örni, what windows version do you use?
OK another shot in the dark
Maybe his virus scanner is messing with something
Like I said I’m running out of ideas.
[quote=“Wrong Way”]OK another shot in the dark
Like I said I’m running out of ideas.[/quote]
I think he has a problem with his arduino installation.
Especially on Win7 and higher there are some ways for thet to fail.
Check Arduino IDE version, it should be 1.0.6 not 1.6.x
If it’s an install problem you can download the non admin zip file in this link.
http://arduino.cc/download.php?f=/arduino-1.0.6-windows.zip
There in no install just unzip it and run it from the unzipped directory.
I didn’t pay attention to that yesterday. In fact it compiles, but maybe source of some of my problems.
Hello
i was by the aduino days in Zofingen.
My Problem was i had more then one Folder with the library. I forgot to deleat the second library.
Now it is working.
Thanks for the help.
[quote=“gjoliet”][quote=“ichbinsnur”]
1.0.6 or 1.6.0?
Marlin only compiles correctly with 1.0.6.
[/quote]
I didn’t pay attention to that yesterday. In fact it compiles, but maybe source of some of my problems.[/quote]
I solve all my problem. Still running with firmware compiled with 1.6.0 without any problem.
Bonjour à la comunauté et au support !
Je viens de finir le montage et je recherche à faire l upgrade du soft .
Apres 2 h maintenant, je ne comprends pas comment faire et rien sur youtube .
1
Telecharger Arduino IDE 1.0.6
2
telecharger VERTEX 1 HEAD V1.1 ( pour 1 tete)
3
mettre le 220VAC a la K8400 => ENLEVER . No 220V
4
Mettre l usb
5
lancer le logiciel ardino 1.0.6
6
choisire Arduino2560 or Mega ADK
7
choisir le port com de l usb ( 3 pour moi )
8 ?
Dois je mettre une carte SD ? Dois je faire une sauvegarde avant ? J’ai lu qu’il y a vait un Jump pour la mise à jour ? Existe t il un manuel ?
J ai actuellement la version M:1.0 V1.0 2 têtes . Il n est pas possible de choisir le nombre de tete dans les options du LCD
Merci pour votre support
Il faut faire la mise à jour sans brancher le courant ou en détachant le cable qui va aux têtes sinon elle riquent de s’allumer à vide et de carboniser le tube en plastique (comme c’est rappelé sur ce [color=#408040]post[/color]).
Et, oui il faut mettre un cavalier sur les contacts JPROG.
Arduino 1.0.6 c’est OK pas les versions plus récentes.
Les reste c’est OK.
Quand le téléchargement est fini, il faut aller sur le LCD et Sauver les nouvelles configurations dans l"EEPROM (Settings puis 1 “Restore Failsafe” puis 2. “Store Memory”).
Carte SD : pas nécessaire pour la mise à jour.
Non on le peut pas choisir le nombre de têtes sur el LCD, il faut un firmware ad hoc.
