How is it possible to select more Top and bottom layers in repetier host with cura engine slicer ?
My top and bottom layers dont close fine, even in preview.
In top / bottom you enter in millimeters
Example
Number of layers x Layer height = value that you must enter in Top / Bottom.
5 x 0.2 = 1mm
Shell
Number of lines x nozzle diameter = value for Shell
3 x 0.35 = 1.05
So if i understand when i’m using 0.15 layer height then:
Top/Bodem thickness = 0.75
Shell thickness = 1.05
Why 3 number of lines ?
Are these good settings to get my Top and bottom compleet filled ?
As you wrote. Personally, I use 3 on the bottom and sides and 5 on the top for better quality.
Three are just an example.
the number of lines and the number of layers are custom modifiers
