I have installed the same Repetier 1.0.6 from Velleman site to my Win-XP-laptop and Win-7-laptop. Win 7 installation have only Vertex dual head and default alternatives. And the printer starts but begin not to increase the temperature. The Win-XP works fine. There is both Vertex dual head and Vertex single head alternatives.
Why the Win 7 installation do not have Vertex single head alternative?
It looks strange. On all my Win7 installations (4) I’ve both options.
This problem can occur if you don’t have administrator privileges on your windows install, could you check that?
Try rerunning the installer by choosing “run as Administrator” from the context menu when right clickig the setup file.
Thanks for your hints. I found the reason. I had changed the work directory. The “RepetierVertex” -folder must be in the work directory. I moved it there and now Repetier find single and double heads.
Nice to hear you got it working.
I did the same thing and saw on the display of the printer after I started the job that it was waiting for the bed to heat up.
Oops
lol
